Can't find MF Scan Utility after installing it
avrum223
I downloaded and installed the Canon_ScanGear_MF.pkg to my Mac (OS is Sequoia 15.6) but cannot find the MF Scan Utility in my application or any where else.  Now what?
I found the Canon MF3010.app but when I try to pen it I get
avrum223
Thank you.  That was the same scanner driver that wouldn't install for me. I was able to copy the MF Scan Utility from a MacBook Air which belongs to the previous owner of the MF3010. I can now scan with the Image Capture which I suppose is good enough.  The MF3010 must be a really old design since there is no wireless connection, you must use a USB cable.
2 REPLIES 2
If this is for the MF3010, I see the following download available for Mac OS 15.5.  Its likely this might work for 15.6 too.
Canon Support for imageCLASS MF3010 | Canon U.S.A., Inc. https://share.google/z2jhMEEArDfrPjmjJ
Scanner Driver & Utilities for Mac V2.15.17 [macOS 10.14.6 - macOS 15.5]
Note this particular model is released in multiple regions, USA and Central and North Africa.  (ImageClass & iSensys)
avrum223
Friends and Family
