09-18-2019 03:48 AM
I reveived a new G3200 and have not been able to initiate "Easy Wireless Setup". Following the instructions as carefilly as I can, I have pressed and held the "Wi-Fi" button and waited for the "ON" lamp to flash. The instructions do not specify a time, so I'm left to assume that the lamp begins to flash within a few seconds of touching the Wi-Fi button. 30 seconds later, the printer is still lifeless. I have unplugged the printer and touched the "ON" button to discharge any voltage stored by capacitors. I have held the Wi-Fi button down as I plug the power cord into the outlet still nothing. Unless someone has a quick solution, I will be initiating a return tomorrow for, what must be, a defective printer.
09-18-2019 08:36 AM
Hi, wili!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
09-18-2019 03:03 PM
Thanks for your welcome. I was unable to join the printer to the network. I have returned it as a defective unit.
10-03-2019 12:12 AM
