01-22-2013 02:17 PM
Hello,
I am suddenly having problems with my S100. It will not take the picture when I press the shutter release. In case I had accidentally changed something, I did a Reset to Defaults. Then it worked, briefly, before returning to not working. It also would not let me change My Colors. Everything else seems to be working fine. Any ideas?
04-15-2015 05:56 PM
I just ordered the part, with the part number and phone number angeloweb gave. So far so good. Be careful, there are two cameras called S100. The one made 15 years ago is not ours.
04-15-2015 09:06 PM
04-15-2015 09:09 PM
I didn't heat it. What is there is like a thin 2 sided tape. I did not remove it, and it allowed the new FPC to be held in place.
Yes, the old piece is destroyed peeling it from that tape.
04-15-2015 10:22 PM
I welcome hearing your experience with this. The Deoxit fix was only temporary.
04-16-2015 04:21 AM
04-16-2015 04:22 AM - edited 04-16-2015 04:27 AM
Danluckett, mine was still working, but erratically, so time for the operation 🙂
I really want this camera to work because it is the only pocketable camera I have that has manual control and shoots RAW. I have a Panasonic Lumix LX3 and an LX7 (soon), but they are just a bit too big for a shirt pocket.
The S range of small Canon Powershots are great little cameras.
04-16-2015 07:21 AM
It's been a great camera apart from this failure. They have held their value on ebay, and there are hardly ever any "not working" ones offered. I had decided if I couldn't fix it I would get an s120. Good luck.
04-16-2015 08:15 AM - edited 04-16-2015 08:15 AM
Thanks Dan, I finished putting it together tonight and when I was done, it wouldn't power up. I have probably damaged the shutter flex strip when trying to get it back into the connector. It needed a bit of pressure to get it to seat and that may have killed it.
Either that or the new strip that I got from China was faulty, but I doubt that, it looked identical to the old one.
I'm going to order another one from Canon this time and try again 😞
04-16-2015 11:40 AM
Did you notice that Angeloweb said:
"My first attempt to power up after reassembly got no power. I hadn't wiggled the FPC connection that slides in the front of the camera far enough in."
04-16-2015 09:28 PM
