07-26-2015 09:50 AM
Hi, I am new to Powershot SX60 HS. When I try to shoot recently on P mode, the shutter release button is delayed before releasing and this cause my photos to be blurred. I had no such problem previously when I bought the camera a few months back. Can anyone suggest a fix to hasten the shutter release so it will be press and capture instead of press and delay and then capture. Thanks.
08-12-2015 10:23 AM
Sybergoonies,
Since this only happens in low light, it is probably just a slow shutter speed being used. The longer shutter is necessary to properly expose the image in the lower lighting conditions. You may want to increase the ISO speed to compensate. Press the FUNC/SET button, select ISO, then turn the dial to choose an ISO speed. For lower lighting conditions, you will likely need to use at least ISO 800/1000 or higher.
07-26-2015 10:48 AM - edited 07-26-2015 11:46 AM
07-26-2015 03:34 PM
Another cause may be that it's set to 2 second timer mode.
07-27-2015 02:57 AM
07-27-2015 02:58 AM
08-09-2015 01:18 PM
I appreciate your insight. I am also new to canon and have had the same problem when taking photos inside. The delay in the shutter release and the blurred subjects has been frustrating. This seems to happen regardless of the mode so I am assuming this is something I must learn to live with. Any suggestions on how to use this camera indoors or do I need to use my dslr if I want to get a quality picture during family gatherings? BTW I am still trying to transition from the Nikon terminology so not quite sure of all the canon powershot sx60hs settings or functions. I have not found a book (aside from the manual) that provides any insight into the how, what and whys of the various functions available.
08-10-2015 06:47 AM
Sybergoonies,
Press the shutter button down halfway until the subject is in focus and the box is green, then press it down the rest of the way to take the photo. How's the delay then?
08-10-2015 08:19 AM
I have had a frustrating time with this camera. I push the shutter release button down half way as usual. It is rather sensitive and I guess I push it too hard because there is a lengthy delay and than it takes the shot. The subject is blurry and I am missing some great pictures. Is there anything out there that provides suggestions on settings? Most of my photos are taken outdoors in the early morning or early evening just before sunset. I am not getting good photos in aperture, shot priority nor in auto. Any help would be appreciated.
08-11-2015 09:59 AM
celticfiddle,
Set the camera to Playback and select an image you took that is blurry and had a delayed capture. Then, press the DOWN button to cycle to the detailed shooting information display.
08-12-2015 02:42 AM
