02-13-2023 07:19 AM
The AE lock does not work while holding the shutter button down 1/2 way or by using the AE lock button. When trying the AE lock button, the lock symbol does appear in the lower left corner of screen, as it should, but no exposure lock. Not sure what's going on. Wondering if doing a factory reset will help.
02-16-2023 09:29 AM
Thank you for the input. I had previously set the metering timer to 30 sec. so that wasn't the problem. I tried setting c.Fn 1, that didn't help either. But, I went through more settings found Expo. simuation disabled, tried Enable, and that worked! AE Lock working as expected! Again, thanx for helping me discover other settings.
02-15-2023 05:40 PM
Hello Petergs,
From once the AE Lock symbol (*) is displayed, the exposure lock will be unlocked automatically after the metering timer runs out. I would suggest taking a look at that setting in the red camera menu #2, Metering timer. Try adjusting that setting prior to doing a reset on the camera. You can also check the Exposure Safety shift setting. This is found in your Custom Functions menu, under yellow wrench menu #6, C.Fn 1. If that doesn't work, then reset the camera to factory default settings in the yellow wrench menu #6, Reset camera.
02-16-2023 09:29 AM
