01-28-2013 12:03 AM
Can't connect S110 to 4G iphone by Wi Fii.Have Camera Window on phone. Camera LCD says "Connect target device to this access point and start app" and gives SSID and encryption key but no connection results.Any help?
01-30-2013 09:37 AM
Williamhamilton,
I am sorry to hear that you have been unable to connect your S110 to your iPhone. I have provided the exact steps below for your reference, just to make sure everything is being done correctly:
03-29-2013 09:05 PM
I'm having the same problem. I get to the step where I choose the SSID from my phones wifi setting menu and enter the encryption key. My camera says "waiting to connect" then after awhile it will say "Device Not Found". I've tried this a few times, making sure to input the encryption key correctly and it still doesn't work. Suggestions? Thanks
04-21-2013 02:24 PM
I'm having the same issue,
After input the key and tap "join" on my iPhone 5, the loading spinner next to the network name keep spinning but never turns into checkmark, it usually last for a minute or two until the camera give up trying.
I also own EOS 6D and never had any issue connecting.
04-22-2013 06:38 AM
Mayinpeng,
I am not sure whether or not you are doing this, but are you entering the same SSID and key from your EOS 6D to connect to your PowerShot S110 or are you entering the new SSID and key from your PowerShot S110?
04-23-2013 11:47 PM
What im trying to say is:
i own a 6D for over 6 months now and never had any problem connecting it to my iPhone.
when I set S110 as access point and use iPhone to find it, after input the correct key it stuck in "connecting" mode, see below:
FYI my friend's Android had no problem establish connection to S100, it's just my iPhone 5.
04-25-2013 08:34 PM
Hell Mayinpeng,
We're sorry to hear that you continue having issues with your PowerShot S110 connecting to iPhone. We are not aware of any known issues that would prevent these cameras from becoming connected. At this point, we would suggest contacting out over the phone for step by step instruction on this issue.
Please use the Service and Support web site to get in touch with Canon technical support.
10-06-2016 06:07 AM
I recently upgraded to IOS10 on my iphone6.
After that Canon Camera Connect app does not work. Did all resets on S110 camera and iphone6. Deleted and reinstalled app. Still does not work.
Then installed the superceded and old version Canon CameraWindow app AND IT WORKS !!!!
How can I get the latest Canon Camera Connect app to work ????
08-19-2013 11:27 PM - edited 08-19-2013 11:33 PM
@mayinpeng wrote:What im trying to say is:
I had the same problem. Tried to connect, but the connection appear to be 'stuck'. You should try opening up your canon app anyway and see if it will connect. I tried it and it worked for me! 🙂
Been having this problem for a while and now it's solved. Hope this helps.
-MR
03-15-2014 02:33 AM
I am having the same problem. Does this not connect to iphone? Only all other phones except iphone? That's one of the main reasons I purchased this camera. The convenience of having my pictures be transferred to my phone so easily. Has this been fixed already or is a continuing issue with others?
