11-04-2019 12:29 PM
Is something I'm doing wrong or do I have to re-establish my WiFi connection everytime I turn the camera on?
Or, is there a way to automate this; Set it and forget it; Connects automatically???
Looking forward to good advice.
Kevin
11-04-2019 01:30 PM
@kkorotev wrote:Is something I'm doing wrong or do I have to re-establish my WiFi connection everytime I turn the camera on?
Kevin
That behavior may be by design. If you are not actively using Wi-FI, then you will want to keep it disabled. Having Wi-Fi active anytime the camera is turned on would probably drain battery power fairly quickly.
11-04-2019 01:30 PM
Kevin
11-04-2019 02:06 PM
Thanks, Waddizzle,
I hadn't thought of that. Makes sense now.
