06-08-2022 06:52 PM
I purchased a used Powershot G5X a couple of years ago, and I've found that it shuts off while videoing. At about 16:00, the timer turns red and the camera stops videoing. When the timer turns red, I've tried tapping the shutter release button and pressing the video record button to try to keep the camera going to no avail. Tapping the shutter button has no effect on it, and pressing the record button stops the videoing. I am unable to find anything in the settings that would override it. Eco Mode and Powersave mode are both off, but the camera still stops at 16:30. Is there a way to keep the camera recording until I stop it?
06-10-2022 10:58 PM - edited 06-10-2022 10:58 PM
There are two limits to the recording capacity of your model, which I have too.
1. The file storage limit of 4GB as already mentioned. Considering the short time you were recoding, I frankly didn't think you would reached that limit but your information confirms that you have.
2. A second time limit exists (although you have not reached that) which was required to avoid a significant increase in taxes within the EU. Cameras recording over 29'55" were classed as actual video cameras and attracted some serious taxes and duties. The EU has now discontinued that, so many of the latest models no longer have that but it's not retroactively applied to the G5X.
06-11-2022 12:52 AM
I formatted the card with the camera, and there was no change. It still shut off at 16:26. My computer is an HP15-bs134wm laptop.
06-11-2022 07:17 AM - edited 06-11-2022 07:17 AM
If you view properties of the card on your computer, do you see anything about its format? Look for things such as "FAT32" or "exFAT".
If it's FAT32...
If it's exFAT...
Having said all that, another way to get beyond 16 minutes (but still limited to 30) is to decrease the quality of your captured footage.
Finally, if you have the need to capture long-running events, it would be best to use a dedicated camcorder. Or, choose one of Canon's newer mirrorless cameras that no longer have the 30-minute limit. Personally, I prefer dedicated video equipment due to getting some nice video-related features you often don't find on DSLRs or mirrorless cameras.
06-11-2022 01:05 PM
I had heard about the taxes and duties for cameras that would record longer than 29:55, but I wasn't aware the EU had discontinued them. Good to know! Thank you for all of your help! This at least tells me it's not a setting or anything I'm doing but it's something I can't change.
06-11-2022 01:07 PM
It's already exFAT. Figures. As I told Trevor, this at least tells me that it's nothing I can change or am doing to cause it. Thank you for all of the information and help!
