03-16-2014 11:28 AM
Powershot G3, LCD screen now never displays, always black. Cycling through LDC on/off via the "Display" button doesn't help. Fresh full battery (more than one tried). Cause of problem? Solution?
03-18-2014 09:05 PM
Yes that camera goes for about $30 working on eBay, It should becuase I buy the G5's and S5 iS's which are later, better models...the G5's go for about 40 and the S5's for about $60..fully working. It doesnt make sense for you to fix that one.
03-18-2014 09:07 PM
One last thing, If that camera has a video/audio out cable you may be able to see the menus that way to try a reset.
03-16-2014 11:56 AM
Cause...could be one of a half dozen things from a bad lcd, bad interconnect cable to the lcd, faulty main board, perhaps the display switch, a loose connetion....
Have you tried a reset throught the settings menu?
Outside of that is will need to be repaired.
How old is the camera?
When or how did the problem start, like all of a sudden the display went blank while using it or it failed right as you turned it on?
I didnt look up that model but I know the G5 has a swivel display, if your does try moving it around see if u can get the display back that way just make sure the veiwfinder is off.
Does the veiwfinder still work?
03-16-2014 09:27 PM
The G3 is a rather old camera & not worth repairing. If it was in as new condition & worked perfectly it wouldn't be worth much on the used market thanks to progress. You could buy a new camera but before you do (assuming you live in the USA) check what's available through the Canon Loyalty Program.
03-18-2014 11:46 AM
Thanks John and Cicopo.
Yes, the LCD swivels. I've moved it fully.
It started when I first turned on the camera after a couple months not using it.
I'd like to try a reset as you suggest, but how do I do that if the LCD doesn't display?
The viewfinder (near the top of the camera) still works, but it appears to be purely optical like a 35mm film viewfinder camera.
Cicopo: I'm not familiar with the Canon Loyalty Program. Could you indicate how I can access it?
Thanks again.
03-18-2014 07:03 PM
Good point you cant see the menus unless you have an audio/vidoe usb option fot that model
I know working G5's go for around $30, S5 iS's about 50 which is a much nicer camera on eBay yours may be a lost cause
03-18-2014 07:58 PM
Re Loyalty Program see message # 3 here.
http://www.fredmiranda.com/forum/topic/1216295/0?keyword=Canon,Loyalty,program#11585215
03-18-2014 09:05 PM
03-18-2014 09:07 PM
