PowerShot SX530 HS uploading double photos to my laptop
PjsWhitewolf
I recently purchased a refurbished PowerShot sx530hs camera and need some help with a problem I'm having! When I upload the pics I've taken from my camera to my laptop, I get double of each pic! Is there a setting I need to change on my camera so it uploads only the normal 1 print of each pic taken?
2 REPLIES 2
John_Q
Hello PjsWhitewolf,
There is no setting on the camera which would cause this to happen. When you view the images on the card in the camera, do you see multiples of the same images then? That would indicate that you may have used continuous shooting to inadvertently take multiple shots while the shutter button is pressed. If not, then it is a software setting that you would need to look into for that issue.
PjsWhitewolf
hank you John_Q! It must be a software setting! I will check into that! I appreciate your help!
