How to continue using image.canon on PowerShot ELPH 190 IS & EOS Rebel T7
cadblu
Lucky me, I have 2 Canon cameras, a DSLR and a Point / Shoot on the list no longer supported by the Image Connect gateway.  I recently retired and want to get back into photography.  One of these cameras I only owned less than a year before it was no longer supported.  It strikes me a bit odd that Canon couldn't find a work around solution to the so-called security issue and instead just eliminated functionality completely.   looked into Eye Fi options and also the Canon Wi Fi adapter, but both have major issues. Finally, I cannot believe that such a highly regarded and technically competent company like Canon can just push these cameras aside while they made some accommodations to have some cameras continue to function on the image gateway.
Am I the only one that feels this way?  I didn't drill down these forums too closely, but I would hope that there is some activity going on behind the scenes.  Thanks for any comments or suggestions you can provide.
July 6th, 2023
【Important Notice】 Change of supported models due to security enhancement
Thank you for using image. Canon.
image. Canon has ended support for the following products at the following period in order to enhance security.
End of June 2023
You are no longer able to upload images from the applicable products to image. Canon*. Some products will continue to be supported by image. Canon after upgrading the firmware version.
Images already uploaded to image. Canon will continue to be stored, and you will be able to view, download, transfer to connected services, share by emails and transfer to Apps. We apologize for any inconvenience this may cause and appreciate your understanding.
*For CS100, image sharing via image. Canon will also be disabled.
[Applicable products]
20 models that will no longer be supported by image. Canon
EOS series:M5, M6, M100, M2, 6D, 70D, 80D, Rebel T6 / 1300D, Rebel T6i / 750D, Rebel SL2 / 200D , Rebel T7i / 800D, 8000D / Rebel T6S / 760D, 9000D​ / 77D
PowerShot series:G1 X Mark II, G3 X, G5 X, SX530 HS, SX730 HS​, ELPH 190 IS
IXUS series:IXUS 180 / IXUS 182​
Connect Station :CS100​
14 models that will continue to be supported by image. Canon once the product’s firmware has been upgraded
EOS series:5D Mark IV, 6D Mark II, Rebel T7 / 2000D / 1500D, 4000D​ / 3000D / Rebel T100
PowerShot series:G1 X Mark III, G7 X Mark II, G9 X Mark II, SX420 IS, SX430 IS / SX432 IS, SX540 HS, SX620 HS, SX720​ HS, ELPH 360 HS
IXUS series:IXUS 190, IXUS 285 HS
[Schedule]
May 18th, 2023:
Firmware available for 14 models
End of June 2023:
End support for image uploading from 19 camera models and image sharing by CS100.
4 REPLIES 4
Stephen
Moderator
Moderator
Hello.
This service notice was released two years ago. Which camera(s) do you have?
cadblu
  • Powershot Elph 190IS
  • Rebel T7
thanks for your reply!
cadblu
  • Rebel T6 (correction)
kvbarkley
I am pretty sure most of us don't use Image Garden and don't care much either way.
