05-12-2013
08:07 PM
08:48 AM
Out of nowhere, I came up with a memory card error on my canon power shot sx 200 is. Any suggestions on how to correct the problem?
05-13-2013 12:52 AM
05-13-2013 11:07 AM
brand new Power Shot elph 115 Bundle out of box...MEMORY CARD ERROR (Dane Elec sdhc). Camera format did not work. Old SD card worked to take a few mother's day pix. Why would bundled card not work in new camera ????
05-13-2013 11:50 AM
Like all items, some of them are dead on arrival. It's pretyt normal and it could be manufacture error, defective product, shipping and/or packing damage, etc...If it is new, you can exchange for another one.
05-14-2013 04:47 PM
Hi JerryButorac,
As Hsbn mentioned, if you've saved your images and movies to your computer, I'd recommend formatting the memory card. If you're unable to do this, I recommend trying a second memory card. If the memory card error persists unfortunately, your camera will require repair.
You may set up camera repair by clicking here.
09-17-2013 08:43 PM
The best (most dependable, error free) Memory cards are Sandisk brand.. Off the wall brands are iffy at best. Recommonded are name brand cards.
03-24-2015 08:27 AM
How do you reformat the memory card?
03-24-2015 08:49 AM
How do you reformat memory card inside a Canon PowerShot ELPH 115 IS ....I've been searching online, but the instructions are for a different model.
03-24-2015 02:04 PM
Press the menu button, then select the tools menu, scroll down to format, and press func/set button.
Steve M.
10-05-2015 07:41 PM
1. Older Canons (pre-2007) can only use SD cards, not SDHC cards.
2. There is a tiny tab on the left side of the SD card (when you are reading the front, tab is on left side). Slide it up to lock the SD card, and slide it down to unlock it (when you want to use the camera).
3. Remember to format the SD card. See your owner's manual or look on-line to get directions.
If these things don't solve your problem, you may have damaged the SD slot reader. You may have to have them repaired.
