08-09-2024 01:03 AM
I have a PowerShot SD870 IS that I hadn't used in a long time. I charged the battery and the camera worked fine for a couple of minutes then the lens wouldn't retract and I got a "Lens Error". I charged the battery again, I tried starting the camera while holding down the shutter button, and I tried moving a piece of paper around the lens body (to try to clear any obstruction if there was one), but none of that helped. Does anyone have any other suggestions? I was wondering if the camera battery is like a car battery where you can charge it, but it still doesn't have enough power. I don't have another battery or the AC adapter.
08-19-2024 04:12 PM
Thanks for the info Tronhard! My last thing here is if anyone knows of any good aftermarket companies that make batteries for Canon cameras?
11-06-2024 12:26 PM
Hi I have the same model and problem have you figured out the problem? I haven't used mine in a while either and was wondering if it was the ebattery
11-06-2024 01:49 PM
Hi! No, I didn't figure out the problem. Maybe one of these days I will try a new battery. I have a Sony camera which I have never had any problems with, so I am in no hurry to try another battery.
