02-01-2016 01:31 PM
My powershot A1400 is displaying "lens error" . It will neither close nor take a picture....any suggestions?
02-01-2016 07:33 PM
If the lens is sticking out, turn on the camera and GENTLY try pushing the lens back in while using the zoom button. Give it a slight twist to see if maybe some dirt is causing the lens to get stuck. Just don't use too much force or you'll need a new camera for sure.
Try a reset all as well.
Steve M.
02-01-2016 07:58 PM
Before you push anything check if the lens is crooked. Sometimes they get bumped sideways and a push to straighten it can often snap it back. If it's crooked and you push it in more damage could occur.
If if you are sure it's straight then a push in might solve your issue.
02-02-2016 10:16 AM
Thank you. I just worked on it a few minutes and so far, it is working perfectly again.
02-02-2016 10:16 AM
Thank you.
