06-28-2017 12:28 AM
Hi All,
I have just purchased a G9X Camera for work and need to take photos and upload them to an insurers website. They have a specification that the images cant be bigger than 1MB (1024KB). I cant seem to get any images down to that size. The closest I got was with settings S1 and a 1:1 ratio.
Is there a way to take 640x480 photos with this camera?
PS... It's not lost on me the ridiculousness of this situation. (Both asking for the camera to be worse and the meager upload size of the insurer.
Thanks for help in advance.
06-28-2017 03:36 PM
S is a size for emailing purposes.
I suggest you crop the photo in your computer media editor, the smaller the size, the smaller the pixelage or memory.
06-28-2017 03:57 PM
I want to keep the same workflow as I have a staff member who is computer illiterate but needs to perform these tasks. Ideally I would like to just set the camera to a small image size (640x480). The current workflow is: Take photos (up to 20), plug in camera, open browser, upload photos (must be less than 1024kb).
Any extension to this workflow would cause quite a bit of extra time to be wasted. The S1 settings at 1:1 ratio vary in size above and below 1024kb so isn't appropriate. I would like to know whether the camera is capable of taking images for webpages (around 640x480px). I'm looking for some sort of thumbnail image in the settings that I can't find in the manual / or in google that will do the task. I know the camera can do 640x480 because that's a setting for the video resolution.
Thanks
06-29-2017 08:21 AM
This might help you; press playback mode, then press menu: use arrow to move and select
You can navigate to select the following: resize to lower resolution, photo book, slide show, group image and play around to get what outcome you like, save if it prompts you.
Press menu again to return to playback mode.
