01-21-2025
11:35 PM
11:41 PM
Tiffany
I have a G5X Mark II (purchased in 2022) and while in P mode am unable to get Program Shift to work.
Camera is running latest firmware 1.1.0.
I have read the User Manual, pp. 271-273, and have the camera set as described in the manual. Specifically, both the control ring and the rear dial are set to STD.
I have googled for various combinations of "g5x mark II", "program shift", and other phrases but unable to dig up anything relevant.
Using Tools Menu (Wrench), tab 5, "Reset Camera", I have reset both "Basic Settings" and all entries in "Other Settings"
Immediately after reset, and before make any other changes, I place the camera in P mode, press the shutter button halfway, turned both the control ring and rear dial, but shutter/aperture do not change.
Has anybody else seen this issue, and if so were you able to resolve it?
01-25-2025 09:35 AM - edited 01-25-2025 09:43 AM
First, thanks so much for the reply. I have good news to share.
With both the control ring and rear dial set to STD, Program Shift works if the shutter button is not pressed halfway. Repeat, not. Here is what I have found to work consistently time after time:
My expectation was that Program Shift should work while the shutter button was pressed and then held in the halfway position. The reality is it works when the shutter button is pressed and released.
Problem solved.
01-23-2025 06:04 PM
Hi michaelbl,
One thing to check is to only have either the control ring or the rear dial set to STD. A foot note in the manual mentions that the rear dial can only do program shift if the control ring is not set to STD.
Problem solved.
