04-11-2020 11:00 AM
Hi, all!
Can I connect Canon SX40 HS to DVB capture card for video streaming ?
This camera can share live camera ?
Thanks
04-12-2020 12:49 AM
Hi there,
The camera does have an HDMI output so as long as your capture card has an HDMI input and your computer is using streaming software you should be able to see a live image from the camera, however this camera does not have a "clean" HDMI output so you will see exactly what you are seeing on the LCD screen including any of your settings display or any other interface on the screen.
04-12-2020 04:08 AM
Thanks for your response.
I can't see live camera
Yes, both camera and capture card has HDMI But I can see only images and videos that token before and saved on SD card
05-06-2020 11:28 PM
07-02-2020 04:28 PM
Did anyone figure out a solution to this? I'm having this same issue, but with my G9 X. I can't get the camera feed to appear in OBS thorugh the capture card. Everything seems to be connected properly, but all I'm seeing is color bars on OBS.
07-02-2020 04:46 PM
The short answer is no you cannot stream live video, you will only see pictures you have taken output from the HDMI
07-02-2020 04:54 PM
@John_ wrote:The short answer is no you cannot stream live video, you will only see pictures you have taken output from the HDMI
12-12-2020 01:01 PM - edited 12-14-2020 01:49 PM
Hi all,
It looks like I messed up my previous post, but I apologive if for some reason I posted this twice.
It is possible to stream with this camera. I have done it. Basically, you need to go into settings, turn off all items on display. Then, use a mini USB to RCA adapter to get a video output. The HDMI output only outputs in play mode (which is kind of annoying tbh) but it is possible to send an analog video signal through the mini USB as the manual indicates. I have tested it and it works.
Here is a cord if you are interested. https://www.amazon.ca/Video-Audio-Cable-Canon-Camera/dp/B07JLXWWND/ref=sr_1_3?dchild=1&keywords=Mini...
Also you would need this if you are using a computer https://www.amazon.ca/UCEC-Capture-Device-Converter-Windows/dp/B07PS2TD9L/ref=sr_1_3?dchild=1&keywor...
Edit: I should mention that the output does not have full HD. It's about 640p, not what it can record in unfortionately. Also, I forgot to meantion that the focus bar does stay, but it can be made smaller and moved to a corner. I covered this up with my powerpoint in OBS.
12-12-2020 01:51 PM
Interesting...So once you convert it from mini USB to AV and then back from AV to USB your computer sees the SX40 camera as a webcam?
12-12-2020 03:41 PM
@John_ wrote:Interesting...So once you convert it from mini USB to AV and then back from AV to USB your computer sees the SX40 camera as a webcam?
That post is complete nonsense.
