08-21-2016 12:37 PM
Hello,
I’ve enjoyed using my Canon PowerShot A590 IS for many years.
Today, as I've done successfully many times, I tried to Erase All Images. But when I press Menu, the only options I can select are “Resume” and “Transition.” Pressing the bottom "MF" button just toggles between them, and all other selections, including Erase All Images, are grayed.
How can I again make the Erase All Images option accessible again?
Thanks,
Marc
08-23-2016 04:46 PM
Hi Marcgrobman,
Thank you for taking time to post.
So we may better assist you, please let us know the following:
08-23-2016 10:59 PM
Sorry, I do not know. I do know that after I reported this problem I still had room on the memory card because I was able to take more pictures and download them to my PC. And when I went to the Format option you asked about it said 7.4GB and only 106kb used
A year ago I replaced the original memory card, as it could only hold about 30 pictures, with one that has substantially more memory, but I do not know the brand. I assume the size is a bit more than 7.4GB if that’s the above reading means. Ever sinceI installed this memory card I’ve never again seen an error message saying no memory was left.
No, at least not in word form. But if an error message appeared in the form of an icon or symbol I might not have noticed it. My user’s manual index doesn’t show a listing of error messages.
I’m not familiar with the write-protect switch or the metal contacts you refer to. The only switch my user’s manual identifies is the “mode switch.” If you’re referring to something else please describe and I’ll check.
Yes! Of the three menu headings (the one on the left with first option listed “slide show” and the middle one with first option “print”) the selections under the settings heading are the only ones that appear accessible, including the “format” option.
Thanks again for responding!
Marc
08-23-2016 11:45 PM
Update!
Hi Richard,
Regarding your question
Looking through my user’s manual I happened upon a mention of the “write protect tab” (A very good user’s manual, if it only had a more complete index that included "write protect" something and many other items.) The card was in the unlocked position. I tried putting it in the locked position, and got warning messages it was in the locked position, but I still could not access any Playback menu options other than Resume and Transition. I unlocked the tab again and put the card back but still could not toggle to Erase All Images.
Regards,
Marc
