08-20-2016 09:53 PM
Hi, I'm new to the community and have my first Canon. Love the camera, an SX50 HS, but am having trouble with a new SD card. It is a Lexar 128MB SD. I have it in the unlocked position. When I put it in the laptop it reads the card and says folder is empty. My son had a few songs on it, but I deleted those. When I put it in the camera it says card error and that it is locked. I figured it needed formated to the camera, but the format is grayed out on my camera. Anyone know what I should do?
08-20-2016 10:03 PM
08-20-2016 10:07 PM
I'm sure hoping you mean the card is 128GB, not 128MB. If it is 128MB, that camera is not compatible with that card.
Double check that the card is in the unlocked position. I've had it happen to me that the card got locked when I inserted it into the camera. You might also try a camera reset all from the menus. If that doesn't work, take the battery out for about an hour, then before inserting the battery, press and hold the power button for about 10 seconds, install the battery, and see if you can format the card. Also, if you have another card, see if the camera will allow formatting with the other card installled.
Steve M.
08-21-2016 12:05 AM
08-21-2016 12:07 AM
08-21-2016 04:11 PM
I have an old 3 megapixel camera that used the 128mb card, and tried to use it in a newer 14 megapixel camera and had the same error. With the higher megapixel counts, the photo file would be too large to even fit on the old card. So glad it wasn't the camera itself! Happy shooting!
Steve M.
08-21-2016 04:23 PM
Thats good news glad its not your camera!
As an FYI I've used up to a 256GB card in my SX50 which is way more than I need but it worked too.
08-21-2016 09:02 PM
08-21-2016 09:11 PM - edited 08-21-2016 09:12 PM
Your welcome and when you get a chance google this photographer he does a whole series of "how tos" in photography AND he uses our camera the SX50...I think there are 10 parts on you tube on all the different areas of photography his title is M West Photograpy....I learned an awful lot wathcing them
08-21-2016 10:14 PM
