05-20-2023 09:07 PM - edited 05-20-2023 09:10 PM
I read through the manual the only way to take a bulb exposure,according to the manual is to depress the shutter button and hold it. Then they tell you to be careful don’t move the camera. Well that’s impossible when I’m trying to do a four minute exposure.
I then went to the Canon connect app, and I see that the bulb exposure slider is grayed out for my Canon G5x Mark II. Has anyone got any ideas in performing long Bulb exposures remotely with the G5x Mark II?
I also need to have the camera display completely off since I’m doing it in a dark room so using touch shutter, also will not work.
Bob
05-21-2023 01:32 AM
boatman,
The only way you are going to be able to accomplish is through the use of a remote control.
One thing you could look into is a JJC BTR-C1
This is a wireless remote that uses Bluetooth pairing with your camera.
Amazon also sells a Bluetooth wireless remote made by Pholsy that is compatible with your G5X Mark II.
Steve Thomas
05-21-2023 03:40 AM - edited 08-22-2023 06:33 PM
Thank you for your reply. I’m going to purchase the Canon model remote BR-E1 and see if it will function for this purpose. I read through the manual. I don’t see anything in there about bulb exposures in holding the shutter open using it but I did read one review that stated not specifically for my camera model though, if you press it once it will open the shutter and that the second press will close it. So I’m going to give it a try and I’ll touch base back here for the results.
***Update The Canon BT remote works well for bulb exposures with my G5x Mark II and my new EOS M200!
Bob
05-21-2023 05:02 AM
Yay! It works the Canon BR-E1 remote allows activation of the shutter for bulb exposure!
Bob
05-21-2023 01:32 AM
boatman,
Steve Thomas
Bob
05-21-2023 05:02 AM
Bob
05-21-2023 07:52 PM
boatman,
I'm glad.
Steve Thomas
