04-01-2022 07:37 PM
04-01-2022 07:49 PM
Hi tkrieg,
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what operating system and type of computer
equipment you are using, and what program you are printing from. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
04-01-2022 08:24 PM
I am using a desktop PC running windows 10, I am trying to print checks from Quickbooks 2020 desktop. I want to reverse the check number order. From front to back. Thank you
04-02-2022 12:44 PM
The printer driver supports reverse order printing. This setting is located under the Copies section on the print driver.
Your intuit application might not allow this, but you can try setting it up and testing. I typically make a copy of a page of checks, they use it to test printing, alignment, etc when dialing in the settings I want.
04-11-2022 05:47 PM
Hello Tkrieg,
If you are printing from Quicbooks and you want to reverse your page order, you can try changing the settings in Quicken itself.
If you continue to have the issue and you have also tried to change the page order settings in our printer driver window, I would suggest contacting support at 1-800-652-2666. Our agents would be happy to assist.
04-11-2022 06:18 PM
I have looked under the printer setup in Quickbooks and there is not an option for front to back or back to front. i have also looked in the copy section for the printer driver and can't find one there either.
