05-26-2022 08:03 PM
06-01-2022 04:16 PM
Hello,
If the printer is giving you a paper jam error message, you can try removing the toner cartridges and checking the inside of the printer for any jams or obstructions. You can also use the steps in the link HERE to check the other areas for a jam.
If checking the printer did not resolve the issue, it would mean the printer needs service. The code is not something that can be reset. The message will come up, when the printer can't move a part properly or if one of the jam sensors is detecting an obstruction. In that situation, you can contact our support teat at 1-800-652-2666. They would be able to check the hardware and provide any service options.
