07-07-2020 10:29 AM
i have a mf8500c that the black prints very poorly. i would like to remove the toner tray so i can clean the glass on the laser. i have looked at the repair manual but still can't figure out how to get it out. i think this printing problem is caused by a lot of humidity in the room it is in. so i need to get to the laser glass to clean it. thanks for any help.
07-09-2020 12:53 PM
Hi lazersgm.
To prevent damage, those components are not generally accessible. The toner cartridges for the MF8500C series are self-contained; modifying and removing parts from the toner cartridge is dangerous and not supported.
To correct printing problems, I recommend the automated cleanings and special processing settings; more information is available at the following page in the Online Manual:
07-09-2020 05:29 PM
thanks for the reply. i am not looking to open the toner. that is self contained. i want to remove the tray that slides out that the toner is in. that way i can look up in to the printer and clean the glass that the laser comes through. i think that is has condensation or dirt on it and that is why the black is not printing correctly. it will print a bit better if i leave the printer on a few days and run the cleaning cycle a bunch of times. but it is still very light and streaked. i think if the printer is on a long time it removes some of the condensation from the lens and lets it print better. i use to repair laser printiers for ibm a long time ago. "20+" years. so i know how bad toner can be
