imageCLASS MF753Cdw Trouble calibrating scanner & UPS question
Markg2
#8 'Using Color Correction'. I followed the Setup instructions and placed the paper with color bars face down on the platen, black edge left top. But when I clicked ok, the setup screen moved on (I don't remember now if there was a message or not) without the opportunity to correct or even if correction was needed. Now on the second day with the machine I went searching for that Setup Color Correction screen and can't find it? Is there but that one chance?
Then on page 8 of the Safety Instructions, it says '...do not connect the machine to uninterruptible power supply'. That makes zero sense. If I can connect a computer, monitor, routers to the UPS why on earth not the printer?
Mark
1 REPLY 1
Hector
Hello,
The color correction is something that is done during the initial setup and you can perform it later on if you run into any print quality issues. After the setup, you can correct or adjust the color using the steps in the link HERE. You can also set the printer to perform automatic adjustments.
