imageCLASS MF743Cdw Mac Says "Connecting to Printer" and Freezes
dchrisman
My mf743c does not want to print from my mac connected via USB.  I checked for updated driver, updated printer firmware, on BigSur 11.1 OS.  Dialog box says connecting to printer and freezes.  I've reset mac printing system following apple instructions.  Can print from iphone or ipad via canon business print app without issue, will also scan to mac via image capture without issue.
2 REPLIES 2
dchrisman
Update, scanning from system preferences/open scanner produces the same result...connecting to scanner and freezes in dialog box.  Still scans fine using image capture
Hello Dchrisman,
If you are able to scan from one program but not the other, it will usually point to security software blocking the software or a service/program on your computer has stopped responding. In that situation you can try restarting the Mac to see if the other program starts to respond. If it does not, you can try turning off any security software running on the computer.
If the scanner still does not work from printers and scanners and the Mac freezes when you try to add the printer, I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to check what is going on when the Mac tries to add the printer
03/14/2023: New firmware version 1.8.1 is available for EOS R6
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.0
01/18/2023: New firmware version 1.1.1 is available for EOS R6 Mark II
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
