imageCLASS MF644Cdw- Setting up "Scan to Email" using Gmail SMTP / help?
ckaas1988
For the past several months, I have tried setting up my MF644CDW to scan to email. I've followed the instructions to the best of my ability, and read a number of posts on here... and yet, I'm still stuck. Turning to this forum in the hopes someone has cracked the code.
Here's what I've done so far:
  • Using RemoteUI, gone to Settings & Registration > Network Settings > Port Number Settings
    • I set the SMTP port to 587
  • Using RemoteUI, gone to Settings & Registration > TX Settings > E-Mail/I-Fax Settings
    • SMTP server: smtp.gmail.com
    • E-mail address: (my username)@gmail.com
    • Password: (my gmail password)
    • Use SMTP authentication (SMTP Auth): checked yes
      • Username: (my username)@gmail.com
    • Use TLS for SMTP: checked yes
  • On Gmail itself (a free personal account, if it matters...) I enabled "less secure apps"
Here's what happens when I try to Scan to E-mail:
  • Very quickly, after scanning a document, the printer warms up and prints out a status report. There are not many details: only the number of pages, the destination email, and the word "ERROR"
Did I miss something here? Is there a way to get more information from the printer about what the error actually is - is it an authentication error, something else?
Appreciate any pointers you guys have. Going crazy here...
msdiem510
I finally got this issue to work tonight and thought I'd post it for all others that are experiencing the same.
1- If you are using GMail, you have to setup an 'App Password' for your Canon to work.
2- Go to Google.com and click on your picture (upper right hand corner) and select 'Manage Your Google Account'.
3- Click on 'Security on the left hand side'.
4- Scroll down to section that says 'Signing in to Google'.
5- Make sure '2-Step Verification' is setup.  If it is not, add 2-step verification now.
6- Click on 'App Passwords' to setup a password for your Canon.  You may have to sign into your Google account again.
7- Under the 'Select App' down arrow, select 'Other (custom)'
8- Enter a name for your Cannon.  I put my model number in the field: MF644Cdw
9- Select the 'Generate' button.  This will generate a password.  Copy/Paste this password or write it down.
10- Find your Cannon's IP Address.  I selected 'Status Monitor' on my Cannon; then selected 'Network Information'; then selected 'IPv4'; take down the numbers listed under 'IP Address'.
11- Open up Chrome and enter the IP Address from step 10.
12- Select 'System Manager Mode' option and select 'Log In'.  If you have setup a 'System Manager ID' and 'System Manager PIN', enter that information and then select 'Log In'.
13- Select 'Settings/Registration' button on the right hand side.
14- Select 'TX Settings' on the left hand side.
15- Select 'E-mail/I-Fax Settings'.
16- Select 'Edit' button on the upper right hand side.
17- SMTP server = smtp.gmail.com
18- Email Address = [enter your email address]
19- Check mark 'Use SMTP Authentication (SMTP AUTH)'
20- User Name = [enter your email address]
21- Check mark 'Set/Change Password'
22- Password = [enter the password generated from step 9 above]
23- Check mark 'Use TLS for SMTP'
24- Check mark 'Verify Certificate'
25- Check mark 'Add CN to Verification Items'
26- Check mark 'Use TLS for POP'
27- Check mark 'Verify Certificate'
28- Check mark 'Add CN to Verification Items'
29- Scroll up to the top of the page and select the 'OK' button to save these settings.
30- Select 'Network Settings' on left hand side.
31- Select 'Port Number Settings'
32- Select 'Edit' button in upper right hand side.
33- Change 'SMTP' field to = 465
34- Scroll up to the top of the page and select the 'OK' button to save these settings.
35- Select 'To Portal' link in the upper right hand corner.
36- Select 'Address Book' button on right hand side.
37- Click on '01' link and select 'Edit' button.  Add your email as the first email address.
38- SCroll up to the top of the page and select the 'OK' button to save these settings.
39- Go to your Cannon and test the Scan to Email function.
40- Check email to see if you received the email.  If you didn't get email, check 'Status Monitor/Cancel' button under the 'TX Job Log' section for Error Code specifics.
30 REPLIES 30
I have a MF733CDW and used to use Gmail to send scans but it stopped months ago. I tried using the fix above but got stuck at this step. There is no "Select App" or "App password' section anywhere in my Google acct that I can find. What am I missing?
- Click on 'App Passwords' to setup a password for your Canon. You may have to sign into your Google account again. 7- Under the 'Select App' down arrow, select 'Other (custom)'
mikegmazzone
Hello. This had worked for me in the past. However, it scan to email has recently stopped working. I have tried creating a new password on google. I have used lower case, upper case, spaces, and no spaces for the password, but it is still not working. I also switched the port from 465 to 587, and changed it back, but i am still getting the #802 error code. Does anyone have a solution to this if all instructions have been followed? Thank you.
Starting in Fall of 2024, Google Workspace accounts will no longer support less secure apps, third-party apps or devices that ask you to sign in to your Google Account using only your username and password. For exact dates, visit Google Workspace Updates. To access apps, you must use OAuth. To prepare for this change, review the details in Transition from less secure apps to OAuth.
yustusem
It was working for me within August but not working anymore with the same settings. Firmware updated, but nothing improved. Any news?
According to Google, they are no longer allowing third party apps that send password information.  You can read more at the links included in the following:
What error are you getting?  Unless changed, the default behavior prints a transmission failure report if send fails..
I'm using port 587 and Gmail with an app password.  I just tested.  Working fine.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
dmitry16
Hello, this has all recently stopped working. It was working in September but not in October.
I am using app password and re-checked all the settings.
Still ERROR ( 802 it seems according to the report)
Google says it is allowing app password, not sure what the problem is. We dont have to use  Oauth.
What do we do with out existing Canon MF devices?
Superblue
I used to use my Comcast email account to 'Scan to email' but it stopped working about 2 years ago. I switched to Gmail but it also stopped about a year ago like everyone else. To block spam I believe that these large providers have permanently blocked these ports and made the old solutions useless.
MY SOLUTION: I pay for a hosted domain that I use for hobbies, photos, blog, etc. I configured one of the built in email accounts for scan to email and it works perfectly and reliably. My advice is get your own real domain.
Greetings ,
My experience has been different than yours.  I've used Comcast and Gmail successfully.  I'm still using Gmail today.  Comcast requires that you use the account regularly, otherwise they disable your ability to use SMTP relay.  You have to log into the account periodically to keep it active which I don't do.
Gmail is much more forgiving.  I've been using it for about 3 years.  Recently with both printers I own.  To use Google, you have to use an app password.  My Scan to email has been 100% reliable.  I'm sure a hobby domain would work fine as well.
You're right. Some people seem to have no problem with Gmail, my Comcast acct is old I wouldn't be surprised if SMTP is turned off.
Avatar
