11-02-2020 11:07 AM - last edited on 09-04-2024 01:25 PM by James_C
For the past several months, I have tried setting up my MF644CDW to scan to email. I've followed the instructions to the best of my ability, and read a number of posts on here... and yet, I'm still stuck. Turning to this forum in the hopes someone has cracked the code.
Here's what I've done so far:
Here's what happens when I try to Scan to E-mail:
Did I miss something here? Is there a way to get more information from the printer about what the error actually is - is it an authentication error, something else?
Appreciate any pointers you guys have. Going crazy here...
12-03-2021 07:27 PM
I finally got this issue to work tonight and thought I'd post it for all others that are experiencing the same.
1- If you are using GMail, you have to setup an 'App Password' for your Canon to work.
2- Go to Google.com and click on your picture (upper right hand corner) and select 'Manage Your Google Account'.
3- Click on 'Security on the left hand side'.
4- Scroll down to section that says 'Signing in to Google'.
5- Make sure '2-Step Verification' is setup. If it is not, add 2-step verification now.
6- Click on 'App Passwords' to setup a password for your Canon. You may have to sign into your Google account again.
7- Under the 'Select App' down arrow, select 'Other (custom)'
8- Enter a name for your Cannon. I put my model number in the field: MF644Cdw
9- Select the 'Generate' button. This will generate a password. Copy/Paste this password or write it down.
10- Find your Cannon's IP Address. I selected 'Status Monitor' on my Cannon; then selected 'Network Information'; then selected 'IPv4'; take down the numbers listed under 'IP Address'.
11- Open up Chrome and enter the IP Address from step 10.
12- Select 'System Manager Mode' option and select 'Log In'. If you have setup a 'System Manager ID' and 'System Manager PIN', enter that information and then select 'Log In'.
13- Select 'Settings/Registration' button on the right hand side.
14- Select 'TX Settings' on the left hand side.
15- Select 'E-mail/I-Fax Settings'.
16- Select 'Edit' button on the upper right hand side.
17- SMTP server = smtp.gmail.com
18- Email Address = [enter your email address]
19- Check mark 'Use SMTP Authentication (SMTP AUTH)'
20- User Name = [enter your email address]
21- Check mark 'Set/Change Password'
22- Password = [enter the password generated from step 9 above]
23- Check mark 'Use TLS for SMTP'
24- Check mark 'Verify Certificate'
25- Check mark 'Add CN to Verification Items'
26- Check mark 'Use TLS for POP'
27- Check mark 'Verify Certificate'
28- Check mark 'Add CN to Verification Items'
29- Scroll up to the top of the page and select the 'OK' button to save these settings.
30- Select 'Network Settings' on left hand side.
31- Select 'Port Number Settings'
32- Select 'Edit' button in upper right hand side.
33- Change 'SMTP' field to = 465
34- Scroll up to the top of the page and select the 'OK' button to save these settings.
35- Select 'To Portal' link in the upper right hand corner.
36- Select 'Address Book' button on right hand side.
37- Click on '01' link and select 'Edit' button. Add your email as the first email address.
38- SCroll up to the top of the page and select the 'OK' button to save these settings.
39- Go to your Cannon and test the Scan to Email function.
40- Check email to see if you received the email. If you didn't get email, check 'Status Monitor/Cancel' button under the 'TX Job Log' section for Error Code specifics.
08-27-2023 11:17 AM
Thank you, this worked for me as well.
10-09-2023 12:53 PM
Worked like a charm on my MF642Cdw.
Initially I couldn't see the Network settings, but when I signed into the Remote UI as the Manager, it was all there.
Thanks so much.
12-26-2023 12:57 AM
I did all that and i still get the 802 error.
What is going on?
01-13-2024 01:17 PM
Thank you! This worked for my MF656Cdw
01-18-2024 06:34 PM
Wow these are great instructions and it worked perfect! Canon should pay you for this. Thank you!
08-09-2024 01:22 AM
what a lifesaver. I created an account just to say thank you to you!!!! 😁
03-16-2024 10:17 AM
Thanks for helping, I just hope this would have worked with my MF650C. For some reason I still get #752 errors and long time outs when trying something.
03-16-2024 10:20 AM
Thanks for joining the conversation, jlap777! It sounds like you've got both a different printer and a different error message than what this thread is about. If you need help, we recommend starting a new thread dedicated to your issue. To do that, just click HERE.
08-17-2024 07:26 AM
I have a MF733CDW and used to use Gmail to send scans but it stopped months ago. I tried using the fix above but got stuck at this step. There is no "Select App" or "App password' section anywhere in my Google acct that I can find. What am I missing?
- Click on 'App Passwords' to setup a password for your Canon. You may have to sign into your Google account again. 7- Under the 'Select App' down arrow, select 'Other (custom)'
09-04-2024 12:41 PM
Hello. This had worked for me in the past. However, it scan to email has recently stopped working. I have tried creating a new password on google. I have used lower case, upper case, spaces, and no spaces for the password, but it is still not working. I also switched the port from 465 to 587, and changed it back, but i am still getting the #802 error code. Does anyone have a solution to this if all instructions have been followed? Thank you.
