11-02-2020
11:07 AM
01:25 PM
James_C
For the past several months, I have tried setting up my MF644CDW to scan to email. I've followed the instructions to the best of my ability, and read a number of posts on here... and yet, I'm still stuck. Turning to this forum in the hopes someone has cracked the code.
Here's what I've done so far:
Here's what happens when I try to Scan to E-mail:
Did I miss something here? Is there a way to get more information from the printer about what the error actually is - is it an authentication error, something else?
Appreciate any pointers you guys have. Going crazy here...
08-27-2023 11:17 AM
Thank you, this worked for me as well.
10-09-2023 12:53 PM
Worked like a charm on my MF642Cdw.
Initially I couldn't see the Network settings, but when I signed into the Remote UI as the Manager, it was all there.
Thanks so much.
12-26-2023 12:57 AM
I did all that and i still get the 802 error.
What is going on?
01-13-2024 01:17 PM
Thank you! This worked for my MF656Cdw
01-18-2024 06:34 PM
Wow these are great instructions and it worked perfect! Canon should pay you for this. Thank you!
03-16-2024 10:17 AM
Thanks for helping, I just hope this would have worked with my MF650C. For some reason I still get #752 errors and long time outs when trying something.
03-16-2024 10:20 AM
Thanks for joining the conversation, jlap777! It sounds like you've got both a different printer and a different error message than what this thread is about. If you need help, we recommend starting a new thread dedicated to your issue. To do that, just click HERE.
08-09-2024 01:22 AM
what a lifesaver. I created an account just to say thank you to you!!!! 😁
08-17-2024 07:26 AM
I have a MF733CDW and used to use Gmail to send scans but it stopped months ago. I tried using the fix above but got stuck at this step. There is no "Select App" or "App password' section anywhere in my Google acct that I can find. What am I missing?
- Click on 'App Passwords' to setup a password for your Canon. You may have to sign into your Google account again. 7- Under the 'Select App' down arrow, select 'Other (custom)'
09-04-2024 12:41 PM
Hello. This had worked for me in the past. However, it scan to email has recently stopped working. I have tried creating a new password on google. I have used lower case, upper case, spaces, and no spaces for the password, but it is still not working. I also switched the port from 465 to 587, and changed it back, but i am still getting the #802 error code. Does anyone have a solution to this if all instructions have been followed? Thank you.
