05-01-2023
03:09 PM
09:17 AM
Hello....imageCLASS MF644Cdw.....Printing from Windows PCs works fine. When printing from iPhone/iPads, the text is faded. I saw an older post that this is due to some Eco setting. However, I can't find where to make this change. Any advice is appreciated.....thank you
05-16-2023 02:31 PM
Hello Castle66.
If you are getting light prints from an iOS device, you can try turning off toner saver in the quality settings or you can adjust the toner density. You can adjust those settings from the operation panel on the printer using the steps in the link HERE. If those settings did not resolve the issue, you can try printing from your iOS device using our Canon print Business app.
