imageCLASS MF642Cdw Your printer needs attention/ Printer toner error?
mohamed7
Hi all,
we are using canon mf642c ink jet printer in our office.
The printer is out of toner ink but stills printing for couple of users but one of the user is receiving error on his laptop and not able to print as in the attached image.
can we bypass this error and print like other users doing?
thanks in advance
Like a low fuel warning in your car, the printer is telling you it needs toner.  The printer will eventually stop printing for everyone.  You may do as you wish, but using the printer until it doesn't have any toner left (at all) is not recommended. The warning is there to tell you its time for new toner, not to run it 100% down until it quits.  The printer is not designed to continue printing with empty toners installed.  To prolong its life, I suggest you replace what's low sooner rather than later.
4 REPLIES 4
The MF642Cdw is a laser printer. It uses toner. It is not classified as an inkjet.
The issue is exactly what you describe, the printer is out of toner.  Tap the consumables icon on the LCD screen.  It will show you it's toner levels.  Replace the one(s) that are low or empty.
thank you for your response.
since other users are printing without any issue, can the affected user have to configure any setting to print just like others??
thank you for your valuable comments
