Unable to download Firmware update for MF642C
digitalox
Hello,
I'm unable to update my firmware on my mfc462CDW due to my serial number being rejected. I'm not sure why it needs my serial number and from searching the forums this seems to be due to an old bug in the system where it doesn't accept serial numbers that start with a number. Is there a workaround? We would like to get the latest security updates and such.
Regards,
Scott
8 REPLIES 8
Stephen
Moderator
Moderator
Hi, Scott.
Can you please verify the model of your printer?
Canon doesn't make an MFC line (I think that's Brother's naming scheme), and we don't have an MF462Cdw. We do have an imageCLASS MF462dw, a monochrome (black-and-white) laser printer. You can get info on it HERE.
digitalox
Hi Stephen,
Apologies for the confusion on my part, it is MF642C.
Thanks,
Scott
Does your printer have internet connectivity, wired or wireless?
Look at the printers LCD, scroll to the right and look for an icon that looks like the printer with a blue arrow aiming down.  Tap that and be patient.  The download and verification step takes a little time.  Finally, you should be prompted to restart the device.  Once started, do not press any keys or send jobs to the printer until complete.
Unfortunately, the screen is cracked so I'm not able to use that functionality. I tried connecting to its http portal but didn't see that option on any of the screens.
Regards,
Scott
Without the LCD, you'll have to perform the update using the update utility.  To do that you'll need your serial number. If you log into the Remote UI, you can verify the product's serial number there.
I have its serial number which starts with 2LQ*****
The support pages here will not take it and give the message "The serial number you have entered is incorrect, or does not belong to an applicable product. Please check the product serial number and the applicable product to make sure it is correct and re-enter it in the field."
I've searched the forum and found other users years back with the same issue due to bug of the system not accepting serial numbers starting with a number. I can't even register it so I am stuck.
Greetings ,
Just one extra step then.  Call support tomorrow morning. They will assist you. They'll get your serial number added and send you a link for the download.  When you speak to the support rep, tell them that you don't think your printer's serial number is in the database. 🙂
1(800) 652-2666
Will do, thanks much!
