05-02-2018 03:16 PM - edited 05-03-2018 11:00 AM
Selected paper size is larger than physical scanning area. Cropping will occur. Continue?
01-12-2022 02:35 PM
I have been having this since Windows 11 update or maybe a few weeks prior. After coming on the forum I was able to fix the issue finally. What helped me was opening Device Manager from the start menu. Finding Imaging Devices, underneath found the Canon scanner. Right click and disable device and then enable device. Afterwards the scanner worked without that error box and I have also noticed it was scanning much faster again.
05-04-2018 04:30 PM
05-07-2018 07:39 AM
Thanks.
The scans do seem to work okay if I click "continue"
05-11-2018 09:21 PM
I just noticed that I don't get the warning dialog if scanning from the document feeder, only the glass.
05-22-2018 06:11 PM
Hi rdefuria
In order to properly assist you, I will just need to know what operating system you are running? Additionally, how is your imageCLASS unit being connected (USB or Wireless)?
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
06-10-2018 03:02 AM
I have the same problem as rdefuria and csvanhoeven, on my i-SENSYS MF735cx.
Windows 10 (64-bit, April 2018 update), Canon MF Scan Utility v1.5.0.0, MF735cx driver v21.81, Canon MF735cx overall software package installer v5.4.0.0, MF735cx firmware is up to date (I don't recall what version, but this was confirmed two days ago by Canon support for other reasons).
Every time I scan from the platen glass from the scanner console by tapping Scan -> Computer, the computer to which the scan should be delivered pops up the message:
"Selected paper size is larger than physical scanning area.
Continue?"
Looking at the http://{my MF735cx IP address}/ System Manager interface, the configuration for every scan type for paper size is A4. A4 is, obviously, not larger than the physical scanning area.
Canon, please help us fix this. It's a huge interruption to have to Every. Single. Time. ... we scan from the scanner to the computer, walk back to the computer to click "ok" to dismiss this erroneous prompt.
thank you,
08-01-2018 12:46 AM
Same problem for me!
This has started appearing since the last month: if I scan from the feeder, it is ok. If I scan from the glass, it showes me the error:
[Window Title]
[Content]
Continue?
[OK] [Cancel]
Canon Support team, can you please look into this?
01-15-2019 12:59 AM - edited 01-15-2019 01:04 AM
Same exact problem... Windows 10 1803, MF733CDw, and it was NOT occurring when the machine was running 1709. Canon, this thread has been around for months. Where is the fix for this?
01-15-2019 08:43 AM
I re-installed the driver/package from the canon website. However, you lose the toner amount indicator. But there is no more error.
Having said that, Canon support team does not even care at replying or looking at the reported issue! Pathetic!
01-15-2019 10:11 PM
Appreciate the tip. Thanks
