05-02-2018 03:16 PM - edited 05-03-2018 11:00 AM
Selected paper size is larger than physical scanning area. Cropping will occur. Continue?
10-09-2021 04:18 PM
Yes, happened to me too.
I've been use Canon 731c for many months with NO problem
Then update to NEW SOFTWARE .... Now many problems follow
1) ... This paper warning ...
I have to run up and down between Printer and Computer which is very BAD
I don't have to that before software update.
2)... Scan to Email --- WON'T WORK anymore ..... WHY WHY WHY ...??
I scaned to my Gmail with ease before ... Now I can't do it
. . . . and I can't do it for years now.
I don't understand why change when the printer run great with NO PROBLEMS.
After software update .... The Canon Printer goes BAD .....!!!
I tried to erased everything .... every canon drivers and reinstall an OLD DRIVERS that came with the printer.
..... BUT .... Problems won't go away.
Now I gave up ... just use my $70 HP to scan to Email
HP Printer cost less 5 + times less and working GREAT ....!!!
When canon will come out with NEW & BETTER softwares to fix these problems ...? .... WHEN ..??
01-12-2022 02:35 PM
I have been having this since Windows 11 update or maybe a few weeks prior. After coming on the forum I was able to fix the issue finally. What helped me was opening Device Manager from the start menu. Finding Imaging Devices, underneath found the Canon scanner. Right click and disable device and then enable device. Afterwards the scanner worked without that error box and I have also noticed it was scanning much faster again.
08-24-2022 08:14 AM
Thank you! This was driving me nuts.
09-16-2022 08:45 PM - edited 09-16-2022 08:49 PM
I have a MF232W
On the Printer itself
Menu -> Printer Settings -> Force when Paper Size Mismatch -> Force Output
05-23-2023 11:56 PM
In my case this was a firewall issue. Make sure you allow svchost.exe to access UDP port 8610 on the printer. If that doesn't immediately work, disable and enable the scanner as described in another post in this thread.
09-16-2023 11:47 AM
Thank you the disable and enabled even worked for Windows 10, after some updates we done. Thank you very much.
01-06-2024 03:08 PM
Thanks, solution (disable then enable) works for me under the Device Manger > Imaging Device > Canon ....
05-20-2025 05:56 PM
This fix worked for me. I have an MF232w and an MF260 II. I don't know which one was throwing the error screen, but I disabled both in Device Manager and then re-enabled as you suggested. No more error screen!
