imageCLASS MF624Cw Errors out Constantly
amckain
Hello -
I own a Canon image class MFW624C printer that is suddenly erroring out every time I try to print something. I've now tried on a PC, a Windows OS laptop, and a macbook and have gotten the same results. The only way I  can print successfully is from my iPhone and even that is sporadic at best. Can someone help me figure this out so I can get back to using my printer?Screenshot 2024-04-24 135312.png
3 REPLIES 3
To start, please tell us how the printer is connected and to what?
Wi-Fi
Ethernet
USB
Then, let's pick one device (that's not working) to test with.  We can move forward from there.
It's connected through Wi-Fi and I'd love to get it working on my Lenovo desktop!
MF624 Color Wireless
Windows Desktop
OK.
Support Portal:
Canon Support for Color imageCLASS MF624Cw | Canon U.S.A., Inc.
#1 [Windows 64bit] imageCLASS MF628Cw/MF624Cw MFDrivers (UFR II / FAX / ScanGear
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAwNjg0MTA1&cmp=ABR&lang=EN
# 2 [Windows 32bit & 64bit] MF Scan Utility Ver.1.21.0.2
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNjg2NTAz&cmp=ABR&lang=EN
Start by downloading the files above.
Next log into your router and confirm the IP address assigned to the print and the IP address assigned to the computer.  You can see them in the list of attached devices.  Note both.
Optional step, but recommended:  Assign a static IP to the printer. Once set, restart the printer and verify it has the static IP you assigned.  You can verify by performing the following.  PING IP from a command prompt, or open a web browser and enter the IP address there.  The printers web server should display.
Once confirmed, remove the printer from your computer.  Then uninstall its drivers.  Now restart your computer.
Run the first download #1.  Then run the #2.  Now perform a test print and scan.  Please let us know the results.
