10-10-2017
10:09 AM
01:34 PM
Good morning,
For the small company I work for, the main office I typically work out of has a really nice big printer with the scanner option. And the printer is wireless which is awesome, I can print, but I cannot seem to figure out how to set up the scan function so the printer sends the scanned document to my Mac Book Pro. Is there some type of series of steps you guys could provide to me so I can get this figured out?
It would save me boat loads of time, I would be so very happy if this could be figured out.
My Mac is:
macOS Sierra
verison 10.12.6
Macbook pro (Retina, 13-inch, Early 2015)
Processor 2.7 GHz intel core i5
and the printer is a Cannon MF620 C Series
Hope this infomation helps! Please help!! Thanks!
11-19-2018 06:13 PM
Hi sdaris.
Please delete and re-register the scanner by following the steps at the link below:
Registering an MF Scan Utility Compatible Scanner
If you still continue to experience an error, please call our Enterprise & Desktop Solutions Divisions at 1-866-261-9362 or 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
11-19-2018 06:34 PM
That took care of it ...
Related question, on scanning to my MacBook I can choose custom 1 and custom 2. Where do I change the settings and how can I rename them from custom to something else?
01-05-2019 11:13 PM
Same problem here.
I can print wireless but cannot get the MFSCAN utility to find the scanner using Bonjour. If I type in the IP address I get a message that the specified printer is not supported. When I try and select the Network Scanner Settings from the pull down it is grayed out.
Mojave - clean install
MF4890DW
Any advice?
01-21-2019 01:24 PM
Hi mdemange.
I will be glad to assist you.
The MF4890dw supports scanning with the MF Toolbox software. The MF Scan Utility is not supported with this printer. Please perform a scan using the MF Toolbox. If you receive an error, please follow the steps below to register the printer for network scanning:
1. Select [Applications] under [GO].
2. Select [Canon MF Utilities] > [MF Toolbox 4.9]. You may receive an error that the scanner is not connected. This is fine.
3. Click [MF Toolbox] next to the Apple icon in the left corner of the screen and select [Network Settings].
4. Select the [MF4800 Series], and then click on the [+] symbol and select [Add].
After the printer has been added, please try the scan again. If the issue persists, or you need further assistance, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
