imageCLASS MF269DW II Language Changed from English to Japanese
hell-on-earth
Hello,
I have Windows 11.  After a recent update, my printer touch panel language changed from English to Japanese (I think it's Japanese).  How do I get it back to English? I've used Google Lens to try to translate the characters but the translation to English doesn't necessarily correspond with the English menus.  I have no idea why or how this happened.  It lost it's connection to the wifi.  I got that restored using Google Lens translation, but it was a super pain.
I've also found the "Initialize all data/settings", which again took it off the network. But I got it back on again.  How do I get the touch panel back to English from Japanese.
2 REPLIES 2
DerrickL
Changing the Display Language on ImageCLASS MF269DW II
To change the display language from Japanese back to English, follow these steps:
Step-by-Step Instructions
  1. Access the Menu メニュー
    • Press the Menu button on the control panel.
  2. Navigate to Preferences
    • Use the arrow keys to scroll through the options. Look for Preferences (設定) and select it.
  3. Select Display Settings
    • Find and select Display Settings (表示設定).
  4. Change Language
    • Look for the option labeled Language (言語). Select it.
  5. Choose English
    • Scroll through the list of languages until you find English (英語). Select it to change the display language.
  6. Confirm the Change
    • After selecting English, confirm the change if prompted.
  7. Exit the Menu
    • Press the Menu button again to exit and return to the main screen.
Following these steps should successfully change the display language back to English.
@DerrickL
Impressive.  🤩
