11-30-2024
02:40 PM
02:42 PM
What is the trick to correctly scanning a document ?
I have a mf267dw II. I use the MF scan utility and the image is all screwed up once it scans.
How do you get ahold of someone at canon customer no service to answer a question
11-30-2024 02:43 PM
Thanks for joining the conversation, Mwhite1!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
09-10-2025 01:09 PM
Hello,
We would be happy to assist, but we would need some additional information to assist further. You can reply to this message with the information below and we can provide some troubleshooting steps or suggestions. For a more immediate resolution I would suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to assist.
1. Are there lines in the scan, are the light or how are the scans messed up?
2.Do you run into the same issue when making a copy?
