imageCLASS MF236n Fixing Assembly "Cannot Clean" error message
Westminster
I have an MF236n and it says can't perform clean up when I try to clean the fixing assembly. I have a brand new Canon 137 toner and it is so faint & leaves lines. I can copy from the glass.
1 REPLY 1
Hector
Hello,
If you are unable to perform a fixing assembly cleaning, you can try opening the printer and reseating the toner cartridge. While the toner is out of the printer, you can inspect the cartridge for any packing material and give it a gentle shake to make sure the toner is evenly distributed inside the cartridge. Once the toner has been reseated, you can try cleaning the fixing assembly again.
If that does not resolve the issue, it looks like something is wrong with the hardware. You can contact support at 1-800-652-2666 or you can log into your MyCanon account to check you service options.
