02-28-2026
01:05 PM
01:54 PM
The last time I was able to print, the copies weren’t centered/sideways. Now the printer tries to pull the paper in, but it ultimately folds, and I get a No Paper message.
Is there an adjustment that can be made? Or something to clean?
I’ve removed the toner cartridge, and I see no debris or dirt.
03-01-2026 11:07 AM - edited 03-01-2026 11:08 AM
If your printer is folding paper when it's being drawn in, there is likely an obstruction or the rollers are dirty or worn. Take a look with a flashlight. You'd be surprised, tiny corners of paper can hide very effectively. Over time paper can all also leave behind residue. You can use Q-tips dipped in alcohol or a clean lint-free cloth with a little alcohol to wipe down or clean the rollers on the feeding mechanism.
