imageCLASS LBP251dw problems detecting printer and installing driver
GeorgeAR
Hello Community,
I work in a mid size organization and in the past year or so we're having intermittent problems with printing affecting various of users of Canon LBP251dw device.
In the cases where the issue occurs the printers are connected through USB.The issue is as following, suddenly the user can't print anything, no documents, no test pages, nothing.
The behavior is that the OS creates a job which passes and it's sent to the printer( disappear from print queue ) but the printer doesn't produce anything and just stays in status "Ready to print"
It's been bothering us for a while and we've tried many solutions but nothing has been working out so far as providing a stable printing without interruptions time to time.
The specification of the hardware and software we use are as following:
PC: HP G400g7
Printer: Canon LBP251dw
OS: Windows 10 Pro
Drivers: Generic Plus PCL6 printer driver v2.90 (latest)
Brand new USB cables different brands.
We even noticed that the driver doesn't install properly when the printer is connected via USB.
That how the installation goes:
Step 1: Here I choose the obvious "Next"
Step 2: On the next step I'm prompt to choose the connection which is used in our case it's USB and I again click on "Next"
Step 3:That's the next screen and I click "Yes".
Step 4: At this moment the installation starts and the first step is to discover the printer.
On this step I also connect the cable to the computer via the USB cable and start the printer as shown in pictures 1,2,3.
Step 5: However after a couple of minutes the printer is not found and the installation cannot continue.
To avoid any other problems this is a completely newly installed OS the installation was made through Microsoft's own media creation tool, fully updated to the latest 22H2, without nothing else installed.
Just to prove that the issue with the driver is not related to OS.
I think that because the driver is not installed properly( as we do it manually ) through add new driver for the existing device that could cause the problems described above, but that needs more testing afterwards.
Can somebody help us to sort out this issue as we have more than 40 printers from this type and it's really bothering as the fix requires disturbing the users, connect->disconnect the USB cable and sometimes even full reinstall of the printer?
Thank you!
3 REPLIES 3
GeorgeAR
Hello,
Any update on that issue?
Thanks!
Thanks for joining the conversation, GeorgeAR!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
Hello GeorgeAR,
If the installer is not detecting the printer during the USB install, you can try removing any stored connections for the printer and then try reinstalling the driver from our support site.
While the printer is connected to the computer, you can press the windows key and the letter R on your keyboard at the same time. In the run box that appears, you can type in devmgmt.msc and click ok. In the device manager window that comes up, you can click on the option for universal serial bus controllers. You can right click and uninstall any connection for USB printing support that appear or any connections that show the printer's name.
Once the connections have been removed, you can disconnect the USB cable and try the install again. You can download the RECOMMENDED driver install from our stie using the link HERE. When the install prompts you to connect the USB cable, you can reconnect the printer to your computer.
If you continue to have issues, I suggest contacting support over the phone at 1-800-652-2666. Our agents would be happy to help.
