imageCLASS MF753Cdw - Help Installing Printer and Scanner Functions
cconlopz
I recently purchased the printer and I used the CD to install it.  However, the only function that was installed is the FAX and I don't know how or where to go from here so that my computer can recognize the printer and print either with USB or wireless LAN
Please HELP
8 REPLIES 8
Moderator
Moderator
Thanks for joining the conversation, cconlopz!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
The MF753Cdw is no longer being sold. A newer version is now available. MF753Cdw II has replaced it.
No problem though.  The first generation is still supported.  🙂
Drivers are available here: (Windows or MAC)
https://www.usa.canon.com/support/p/color-imageclass-mf753cdw
Please follow these steps to get up and running.
Please choose your connection method, use only one.  Wireless is the most convenient since it will allow any device connecting to the same network to use the printer.
Disconnect the USB cable from your system
Remove the printer from your system
Uninstall any incomplete or failed installations, remove all software.
important, restart your system
Visit the link above, select downloads, select your OS.  You need the printer driver and the scanner driver.  For Windows this is the MF print driver UFRII that includes scan gear.  You will also need MF scan utility v1.21.0.2
If MAC,  you need the printer driver utilities and scanner driver utilities.  The fax driver is optional for both.  You don't actually have to install a fax driver as you can fax from the machine if you connect a phone line to it.
Run the print driver installer first, then the scanner utility.  This will get you printing and scanning.
Optional but recommended.  If you plan to use the printer connected to your network, assigning it a static IP is recommended.  This only has to be done once on your router.
**If you will connect the printer using USB, do not plug it in to your system until prompted to do so by the printer driver installer.
I would suggest discarding the CD that came with your device.  It is very old, and is surely outdated.  Canon has not included install CDs with its products for many years now.  It's always best to download the latest drivers available from the support portal for your product.
D2Pierce9
I have two Canon Pixma G7020 Multifunction printers. I am running MAC Tahoe 26.5.2. One of the printers shows the "Open Scanner" option when selecting the printer from the Printers and Scanners list in Settings.  The other does not show this option. I have uninstalled and installed the printer several times.  Any thoughts?
Anonymous
Not applicable
Did you  install the Canon IJ Scan Utility Lite for MAC V26?
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNTMxNzE4&cmp=ABR&lang=EN
D2Pierce9
I did, but the software does not "see" the printer/scanner.
Anonymous
Not applicable
The utility is the only "driver" on the support page for MAC Tahoe v26. I don't know Macs nearly as well as an owner which we have here on the forum. I suspect one of them or Rick will have help to offer you.
DerrickL
The issue appears to be that when I look to see what printers are available to install it lists Canon G7000 series and the "kind" is Bonjour Multifunction.  This is my basement office printer.  The other printer listed is Canon G7000 series-2 (my upstairs office printer) but the "Kind" is listed as Bonjour (no multifunction). These two printers are identical and both are multifunction and both used to work.
We're happy to help.
Since your hardware is another model, can you please start a new topic to keep from co-mingling different devices, operating systems and environments.
Here's a link to help you do that.  😉
https://community.usa.canon.com/t5/forums/postpage/choose-node/true/interaction-style/forum/override...
