09-01-2023
04:51 AM
08:14 AM
I have installed all the updated drivers and hardlined the printer with a usb printer cable.... but when I try to scan from the computer or to the computer the printer/scanner says "Connect Computer" with no menu... It prints from the computer but won't send scans back to the computer...? Any help is appreciated. Thanks.
11-10-2023 03:05 PM - edited 11-10-2023 03:05 PM
Hello,
If you can print, but can't scan and have already installed the MF drivers from our support site, you can try downloading and installing the MF scan utility from our Canon USA support site using the link HERE. To scan, the drivers and MFscan utility will need to be installed. If you continue to have issues, you can contact support over the phone at 1-800-652-2666. Our agents would be happy to help.
02-11-2024 10:47 AM
I was able to use scanner until today. No idea what happened. But it sure is not easy to figure out. I guess I'll have to call and hope I get a tech to help me get this huge problem resolved.
06-09-2024 09:17 PM
what is next after downloading the scan utility? and why is this a problem now? it was working before?
03-18-2025 06:28 PM
OMG I run a small support business and have for over 25 years and I cant even get the scan utility to ruin either. This is ridiculse. There are not even any drivers under windows 11 you have to select windows 10/64 for the drivers to show. It works fine from the scanner to the PC but the scan utility does not work at all. Also noticed the windows scan app wont run tried using that and this was a first. Worthless I guess you get what you pay for, support is horriable.
03-18-2025 07:04 PM
I figured it out works with the scan utility or any other scan utility of your choice BUT you need to put on the remote scan option on the printer before attempting to scan.
04-04-2025 06:28 PM
i can't find that setting on printer
it says select scan type and only gives computer as an option, how do i get to the other setting
