01-06-2023
09:03 AM
09:10 AM
my printer is lbp6020b it was working normally at widows 7, I bought a new computer it works at windows 10, but my printer is not responding to print.
06-23-2023 02:51 PM
After I updated the firmware and driver
Nothing was working for me and I was going in circles. I could not even log into Remote UI as it was unavailable.
I was trying to verify that both the printer and my mac were on the same wireless network (they had to be) and therefore decided to follow this link
In following this link, FINALLY, Ventura (13.2) found Canon LBP622CDW
Hope this helps :
So Go to Settings
General
Sharing
Printer Sharing - it will take you to the Printer/Scanner setting, but this time it will find the printer
01-06-2023 10:35 PM
Are the latest drivers downloaded from the Canon website and been installed on the new computer? Are there any software updates pending for the unit? 🤔
01-07-2023 10:32 AM
yes, I do. but the message communication error.
01-07-2023 10:46 AM
Ok, when preparing to print, say, you try to print this webpage by pressing "Ctrl" and "P" is the printer the target device, or is something else the target?
Is the printer connected to the computer via direct cable or Wi-Fi?
01-07-2023 11:27 AM
Yes, I do. the printer is connected to the computer via a direct cable.
01-09-2023 06:31 PM
My suspicion is that the incorrect port is selected. Try changing the selected port to see if any can communicate with the printer.
06-23-2023 02:51 PM
Hope this helps :
So Go to Settings
General
Sharing
06-23-2023 03:10 PM
Thank you for posting/sharing the resolution! 🙂
