how do I permanently cancel double-sided printing? MF4150 MAC M1
synergate
Printer  MF4150 is old, double sided printing jams the paper. now i have to change it from double sided to single sided each time i start printing. Often I forget  change and the paper jams and it is hard to get it out.
How do I change the settings so that single-sided printing is always set automatically?
Canon MF4150 printer
MacOS Venture 13.3.1 (Macbook M1)
Using the drivers: UFR II/UFRII LT Printer Driver & Utilities for Mac V10.19.14
I usually print google docs on regular A4 sheets
3 REPLIES 3
Arthur
Moderator
Moderator
Thanks for posting!
While our Forum Community members are welcome to chime in, the Canon imageCLASS MF4150 has been retired. That means we do not offer support for the printer or updated drivers. We recommend updating to a more modern printer and reaching out to our Canon Upgrade Program specialist who will go over the best options for upgrading your printer. They can be reached at 866-443-8002.
rs-eos
This should be doable with print settings.  e.g., try selecting "Last Used Settings" for the "Presets" option.  Or, after setting Double-sided to OFF along with any other settings you'd want by default, save the current settings as a preset and use that preset going forward.
macOS Printer PresetsmacOS Printer Presets
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS, EF-EOS R 0.71x
synergate
thank you very much
