10-01-2013 02:54 PM
How do I scan from my computer?
10-03-2013 09:02 AM
Hi cjon4442!
Welcome to the Canon Forums, and thank you for your inquiry! So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
Thanks and have a great day!
03-05-2019 01:03 AM
03-07-2019 12:04 PM
Hi hafidz.
The SSL setting can be enabled from the control panel of the printer. Please follow the steps below:
1. Press the [Menu] button.
2. Scroll to [System Settings], and then press OK.
3. Scroll to [Security Settings], and then press OK.
4. Select [Use SSL], and then press OK.
5. Scroll to [On], and then press OK.
6. Confirm that the setting has been enabled.
Next, turn the printer off for 10 seconds, and then turn it back on.
If you run into any issues, or require any further assistance, please call us at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST.
03-08-2019 01:51 AM
03-12-2019 05:22 PM
Hi hafidz.
The #806 error indicates that the user name and password are incorrect. Are you attempting to scan to an email address, or are you scanning to a shared folder on the computer? If to an email. which email server are you using?
I look forward to your reply. If you need immediate assistance with setting, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
03-12-2019 10:35 PM
Hi Patrice,
I am using gmail. I tried to scan to email. I already set the the smtp port 465 and 587 still having issue. I already upgrade the firmware and driver on the printer. Attached is the information for your reference. I tried both port still have error. I tried all the possibilities. Need help so that i can configure and made these working.
03-18-2019 09:37 PM
Is there any solution and steps that i miss out. Seems there is no reply for a couple of days. I need this printer to scan to the email function works. Your reply is muchly appreciated.
03-19-2019 04:45 PM
Hi hafidz.
I will have to recommend that you call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).While the forum may be your preferred method of communication, the next steps of troubleshooting will need to be provided by our telephone support group.
