11-01-2018 02:30 PM - edited 11-02-2018 03:02 PM
Set up my fax which sends but the will not print out fax confirmation and i cannot find it in the menu settings. how to fix this to where it will print out confirmation fax? i have looked through all the settings there is no tx confirmation setting that i can see.
11-14-2018 06:26 PM
Hi onekevin!
I will be glad to assist you.
You can set the machine to print a TX confirmation report by following the steps below directly at the printer:
<Output Report>
<Report Settings>
<Fax TX Result Report>
Select <On> or <Only When Error Occurs>
Select <Off> or <On>
<Apply>
