Voltage change Canon MF451 printer
asinghvi
I am relocating to India for some time. I want to take my MF451 printer to India. Is there a SMPS inside which will allow 220 volt operation? Is there a jumper inside which can be changed to the required voltage?
Hello Asinghvi,
Unfortunately, the printer does not have an internal jumper available that can be changed that would allow the printer to change voltages. The printer would only be able to work with AC 120-127 V:5.9 A, 60 Hz and we would not have any options to change the power requirements.
6 REPLIES 6
James_C
Moderator
Moderator
Hi asinghvi
Welcome to The Canon Forums!
We appreciate your participation, though we need to let you know that your product appears to be a model that is not supported by our team here at Canon USA. While the community is welcome to chime in, the Canon Community Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click HERE and select your country to find support in your part of the world.
It is the Imageclass MF451 which is a canon USA product.
James_C
Moderator
Moderator
Hi asinghvi
We apologize for confusing your product. The imageCLASS MF451dw is a Canon USA product. Concerning your question, the imageCLASS MF451 does not support dual voltages. The imageCLASS MF451 power supports AC 120-127 V:5.9 A, 60 Hz.
The lack of dual voltage support is just the first issue you will experience.  Retailers do not stock inks for your USA based product abroad.  Unless you have someone who will send inks to you, its best to buy a printer sold for use in the country or region where you will reside.  At the end of your visit or residency, you can donate the printer to  school or church.  This is the most cost effective solution in both the short and long term.
I checked. The toner cartridges are available there. Is there an internal jumper which can be changed to switch voltages? As same printer series is being sold in India rated as 220 v.
Hello Asinghvi,
