08-14-2019 04:58 PM
Hi, I was setting up a printer for use at home.
I'm using a USB connection to a macOS Sierra 10.12.16. I've installed the recommended and optional drivers from Canon's website here:
I have no problem with scanning and copying things with the printer, but when I send things to print, it doesn't print. On the printing que, it says that the job is:
Printing - Connected to printer.
But nothing is happening. What should I do?
08-15-2019 06:23 PM
Hi EatAndYeet.
It is recommended that you delete the printer and add it back to the window. Please follow the steps below:
1. Please open System Preferences > Printers & Scanners.
2. Once the window is open, select the MF230 Series in the left column, and then click the [-] icon under the printer list to delete the printer.
3. Click the [+] icon, and then select Add Printer or Scanner.
4. Select the MF230 Series, and then click the drop-down box for "Use".
5. Select "Select Software", and then select the MF230 Series from the list of printers. Click OK.
6. Click Add.
Please print a document and verify if you receive the same error. If the issue persists, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
