01-06-2022 03:51 PM
Hello,
When I try to scan with ADF, the paper comes off fine but then stops, always in the same place. There is no jammed paper debris.
The error code is 103,0,0.
01-10-2022 04:14 PM
I found the solution. It is the plastic tab (with red arrow) on the glass that is blocking. A small piece of adhesive tape, cut with a cutter and it's good.
01-10-2022 04:14 PM
