Problem installing canon mf4350d on windows 10
geni72
I am facing big problem installing successfully canon mf4350d on windows 10. I tried CD instalation kit but when I tried to print there is a message telling “ laser printer driver not available “. Also tried to get new drivers from canon website but same trouble will come up. Any help please?
5 REPLIES 5
What build of windows 10 are you running?
Are these the drivers you are using
How is the printer connected to your network or PC?
Patrice
Whiz
Hi geni72.
Normally this error will appear if the printer is connected to the computer while you install the drivers. If this was the case, please disconnect the USB cable from the computer, and then download and install the installation from the Canon website.
If the issue persists, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
geni72
Thanks for the help. I resolved the problem
What was your resolution?  I have the same issue.
DJonDemand
Windows 11 Pro and it won't work. Sort of stinks to be honest. I really need to use this.
